STANLEY'S WEB SITE
CH-750
Hortizonal Stabilize
7-29-2010
Elev. Alignment
Worked on the up and down movement of the elev. Cut out horn and set the “stops” for upper and lower movement to 28 deg +/-_ 2 deg. per specs. After consider grinding, the elev. is 27.4 deg. Up and 28.0 deg. down.
CH-750 Home
1298
Assembly
113
328
Empennage - HS
Empennage - VS
Forward Fuelage
Rear Fuelage
Service Bulletin
Wing - Left
Wing - Right
Wing Slats
Wings Flaperons
