Fitted the forward right and left skins to rear fuselage. Had to trim angle that goes into the rear fuselage approx. 160 mm to fit properly. Drilled pilot holes in right and left angle, then updrilled them to A-5 per specs. Trimmed bottom longerons on the rear fuselage for a good fit of the rear seat channel.
