Fitted left wing tip. The new wing cap from ZAC fits a little better, although not nearly as good as the right wing cap. Had my wife help install the wing tip while I drilled and clecoed the wing tip. Added the āLā bracket to the spar extension for the middle of the wing tip per specs. Riveted wing caps to wing skins.
Finished installing nav. light bracket on left wing. Used the Molex connectors and left a hole sufficiently sized that the connectors can go through, thus making it easier to work on the Nav. lights. Installed Nav. light ground on the spar extension.
Cleaned and primed the Jabiru engine mount in preparation to take to the community college that is overhauling the 3300 engine.
