Started on forward fuselage. Positioned the longerons, drilled to #40 and clecoed in place. Cut the front and rear of the longerons per specs. Positioned the floor stiffener and clecoed in place. Installed the pedal bearing channel, center pedal bearing and fitted rudder pedals.
