Continued to work on rear fuselage. Drilled remaining rivets holes to spec. and removed right side. Left the right longeron clecoed in place on the fuselage. Deburred, cleaned and primed where necessary and reinstalled the right side to the fuselage. Riveted all of the right side except the forward section where additional components are to be added.
Drilled the remaining rivet holes on the left wing with the side in place. All components had already been cleaned and primed and I only had to deburr a few places. Riveted all of the left side except the forward section where additional components are to be added.
