Deburred, cleaned and primed vertical āLā support channels for rear tank support bracket. Then riveted āLā support to rear channel.
Cut 59 mm hole in fuel tank per specs. Cleaned tank of metal particles. Check fuel level sender with OHM meter to be sure it worked properly, then installed fuel sender.
