Brief Description: Preparations for final assembly
Cleaned and deburred all parts of the elevator. Primed where necessary. Riveted skeleton and riveted entire top skin except to left leading edge. Discovered that I used the wrong rivet head for A-4 rivets and forgot to rivet bracket on the right spar for the right end rib. Remove all rivets on the top skin and right leading edge. Then re-riveted the right bracket for the right end rib, and riveted the top skin with the proper rivet head.
