Located and cut hole for servo arm. Located and drilled holes for servo. Drilled pilot holes in trim tab, then inserted hinge and drilled pilot holes. Assembled trim tab to elevator and drill hole for A-4 rivets. Located and drilled holes for elevator trim tab horn.
