STANLEY'S WEB SITE
Date:  6-5-2009
Number of Hours:  4.00
Manual Reference:  75-TA-2
Brief Description:  Repair Work on HS
After discussion with ZAC, the rudder nose skin is supposed to be riveted on the outside. Removed rivets, and re-riveted nose skin on outside of Rudder. NOTE - This is not clear in the Constr. Manual. With the new rear brackets from ZAC, put the skin on the bottom first, and riveted. Then clecoed the top skin to the skeleton, and riveted.
Re-Riveted Nose Skin
Riveted HS Bottom
Riveted HS Bottom
Riveted HS Top
Riveted HS Top
