Worked on doors to get a proper fit. The left door require a lot of trim to fit correctly. Once that was done, I spent a lot of time getting the three latches to work properly. Finally decided to review the various revisions from ZAC. Finally decided to alum. angle with a nylon pad for the rear latch per the latest revision to the plans. That eliminated the rear latch through the rear vertical support.
