Well, I thought that relocation went too good. I had previously ran the wiring under the seat pan to the center console in preparation of installing the trim switch in the yoke. I was able to work through the lighten hole, and pull the wiring from under the seat pan and reinstall it through a grommet on the side of the seat support on the left side. Also ran the pitot, AOA tubes, ELT remote wires, wing lights wires, and fuel tank level wires in grommets in the seat support and along the side āLā angles to the instrument panel area.
