Started working on the fuel line connections from the wing tanks to the bulkhead on the fuselage. Since I plan to run 3/8” tubing from the fuel tanks to the firewall. Decided to put an access panel on the bottom of the trailing edge skin, near the wing root. This will be an riveted panel. After I test all of the connection for leaks, the panel will be riveted in place.
