Started installing exhaust pipes. After a lot of head scratching and research, I determined that the gaskets I had left were actually the gaskets for the intake manifold pipes, and the gaskets used on the installation of the intake manifold pipes were actually the exhaust pipe gaskets. Removed the intake pipes and replace the gaskets with the proper ones. Then installed the exhaust pipes with the proper gaskets on three of the exhaust pipes.
