Attempted to install bearing seal cover on front of main shaft. Determined that the gasket was installed backward on the plate. Enlisted my neighbor who has a press to help and we removed the seal and reinstalled it correctly. Installed the plate and seal on main shaft. Did some additional clean-up work and installed the valve caps and torque bolts per specs.
