Fitted the trailing spar on the left wing. It took some additional rounding of the upper wing fitting, but all went well. Need to talk to ZAC on the Jury struts to see if the plans are correct as the jury spar will not fit as shown on 75-ZA-5.
Talked to Caleb at ZAC. The vertical jury struts are mislabeled on the plans for Edition 1. 75W7-5 should be on the front spar and 75W7-4 on the real spar.
