Fitted door lock to door and installed bottom doors angle. Still need to put two additional brackets on bottom of door.
Note: The orginal kit contained one set of inside handles. A second set of handles were sent in Jan. 2010 with two additional latch mechanisms. The newer handle did not seem as good and the original handle, therefore, I drilled the older handles and used them.
