Well it’s been a while since I had a chance to work on the fuselage due to some remodeling and year duties. Anyway, fitted the torque tube bearing support. I had previously primed the torque tube. The primer was enough to prevent the torque tube from fitting properly. Had to remove some of the primer to get it to fit properly.
Also started on the main gear. Got the right side drilled for the wheel shaft. That was quite a job. I know that the main gear came drilled for the wheel shafts on latter kits, and I can see why. It was a two hour job just to drill the four holes of the wheel shaft. There must be a better way.
