Fitted front wheel fork to nose gear leg. Since I already installed the nose gear leg, I had to updrill holes for the wheel fork from the bottom. That would have been easier had I done that before it was installed on the firewall. Remove front wheel fork, deburred and primed. I reassembled the fork to the gear leg and lacked one AN4-10 bolt. Ordered several additional bolts from Aircraft Spruce.
