Worked on nose gear and rudder pedals. Installed front gear support including the bottom nylon bushing. Installed brake pedals.
Note: The threads for the nylon bushing is 1 / 4 – 28 TPI. Slow process to tap threads, had to drill the hole slightly deeper to complete sufficient threads for the bolt since I did not have a bottom tap, and couldn’t find one.
