CHUCK'S WEB SITE
Sonex-B Tri-Gear
Cowling
11-3-2023
Spraying Duratec Surface Primer To The Plug
Sprayed the plug surface with Duratec Gray Surface Primer to provide the best possible plug surface for the mold's tooling gelcoat to be applied to.
Three moderate coats applied, with coats being applied "wet" after intial flashing of the surface.
Allowed application to cured 24 hours.
Duratec Gray Surface Primer spray applied to the plug surface.
The surface primer product used.
Sonex-B Tri-Gear Home
1153
142
Cowling
66
140
Documentation
69
81
Electrical System
232
Plans Review
