Tried to install the stick to idler push rod. Discovered the bushing was not deep enough to extend past the material thickness that it was set in. Will order new bushings with longer length to them and fabricate down to sufficient length.
Ground down both bushings to the length specified for the control stick and installed the control stick in the center console area.
