Brief Description: Pilot Drilled Aft 5 Inch Round Inspection Covers.
SNB-F25.
Made paper tmeplates to mount the two aft 5" round inspection covers centered over the 4" inspection holes on right and left sides of tail cone box assembly.Pilot hole drilled and clecoed on the covers to verify placement, then removed the covers for access into the tail cone box.
Note: I will probably use a nutplate to attach the plates but at this time I am still thinking on this. Also note that when right side cover was mounted, two riviets on the side at the top longeron interferred with the covers top edge resting flat on the skin. I will place very small arc cutouts to avoid rivet contact and allow the plate to attach flat against the skin all the way around the circumference.
