Brief Description: Temporarily Installing Jabiru Cylinder Air Baffles
Temporarily installed the Jabiru cylinder cooling air baffles to allow checking the fit with the upper cowling piece. Front of baffles are going to take considerable modification/trimming to make this work.
Trying to use the Jabiru baffles per the suggestion of Kerry from Sonex Tech Support.
removed baffles and will return to this aspect later.
Frontal view of Jabiru cylinder cooling air baffles installed.
Pilot side view of Jabiru cylinder cooling air baffles installed.
Passenger side view of Jabiru cylinder cooling air baffles installed.
