Brief Description: Installing Oil Capture Tank On Firewall
Installed the oil capture tank on the pilot side firewall. Before mounting, ensured the tank position would not conflict with the pilot side vent on the lower cowling. Then, marked the four mounting hole positions. Drilled the holes, then inserted the bolts from the cabin interior through the firewall, and secured the nyloc nuts on the firewall side and tightened.
