Brief Description: Mounting Of Modified Oil Cooler Air Duct
The oil cooler air duct was installed around the oil sump cooling fins, with the mounting end overlapping the newly fabricated oil cooler air duct mounting tab. The points for mounting holes were aligned with the nut plate screw holes and then drilled and deburred.
The three screws were installed to to securely mount the modeified oil cooler air duct.
Trimmed oil cooler air duct mounted to new lengthened mounting mounting tab on oil cooler.
Pilot side view of repositioned oil cooler mounted with modified oil cooler air duct.
Passenger side view of repositioned oil cooler mounted with modified oil cooler air duct
