Brief Description: Adhearing The New Blister Channel To Cowling
I decided on JB Weld's Marine Weld as the adheasive for intially securing the new blister channel to the cowling.
I spread adequate adheasive on both of the contact edges, then positioned the blister and firmly seated it while gently squeezing out the excess adheasive to get the most complete contact possible between the two surfaces. Once in proper position, I installed all seven clecos to lock the position and pull the blister into firm contact.
I did minimal cleanup and spreading of the excess adheasive and let it cure.
Layed a thick bead of JB Weld Marine Weld in all areas of contact then seated and clecoed the blister.
