Brief Description: Filling Bad Holes And Fitting Hinge to Pilot Side
After intial fitting of the piano hinge to the pilot side of the cowling there were some mis-aligned holes that needed to be filled with polyester resin so correctly positioned holes could be redrilled. Once those holes were filled and cured, the new holes were re-drilled and the pilot side cowling hinge piece was mounted with clecos.
Mis-positioned drill holes filled with polyester resin.
A few mis-positioned holes produced while fitting the cowling hinge on the pilot side.
