Brief Description: Moving The Mount Position Of The Oil Cooler Aft
I remounted the oil cooler aft by a few inches. The pilot side oil cooler hose was too short to reconnect. It will have to be rebuilt with a slightly longer piece of steel braided hose. The pilot side hose was long enough that it reconnects just fine.
Moving the cooler aft did resolve the slight contact points with the new blister channel at the firewall end of the channel.
Mounting the oil cooler slightly further aft resolves the blister contact.
The pilot side oil cooler hose was too short to use the same hose.
The passenger side oil cooler hose was long enough to use the same hose connection.
