Brief Description: Continued Fitting Of Cowling To Firewall/Engine
Continued fitting the lower cowling. Once I got to the point where it seems to be a good fit, I installed the cowling hinge piece for each side into the receiving hing piece on the firewall. I then fit the cowling in place and drilled the cowling to the cowling hinge piece for each side with three cleacoes. This took a few attempts, and I have a few holes on the left side that will need to be filled with fiberglass resin.
Downward view of cowling fit to Propeller hub.
Side fit of cowling once temporarily clecoed and secured with piano hinge.
