Brief Description: Initial Fitting Of Cowling To Firewall/Engine
Now that the original blister channel has been removed, the lower cowling fitting process can start since the cowling is now unobstructed from fitting to the firewall sides and bottom edge.
Through multiple iterations of removing a very small amount of material, the sides and bottom edge of the lower cowling were trimmed to fit to the firewall while staying aligned with the prop hub spacer.
Clearance now provided to allow the lower cowling to be fit to the firewall.
Preliminary fit of the lower cowling to the airframe nose.
