Brief Description: Fitting New Blister Channel To Cowling
Laid new blister channel over the original blister channel in the lower cowling to align on cowling.
Once aligned, traced the new blister outine onto the cowling with a Sharpee marker. While keeping the blister aligned with the outline, I drilled 7 temp cleco mounting holes. Once drilling was done, clecoed the new blister channel in place to check fit.
Fit appears good... moving on to cutting out the original blister channel.
Securing forward end of blister channel for cleco mounting.
New Blister channel temporarily mounted over original blister channel.
