Brief Description: Plug Surface Polishing And Waxing
After going through the sanding stages from dry to wet for fine surface prep, mold polish is applied in two steps. Application is made with a small orbital hand buffer using a lambs wool pad.
Once both stages of polish were used and the finish has a nice gloss surface, multiple coats of the mold release wax were applied by hand. Allowing the wax to just start to haze, then buffing it off with a clean, dry microfiber cloth.
Applying polish with an orbital hand buffer.
Applying multiple coats of part release wax to the plug surface.
The two-step polish and the parting wax used. Products from FiberGlast.com.
