Brief Description: Oil Pump Housing Cover Contact Point
Identifying and locating another contact point where the cowling contacts the oil pump housing cover under the propeller shaft behind the propeller hub.
Area of contact with the engine's oil pump housing cover under the propeller shaft.
Backlit area of contact with the engine's oil pump housing cover under the propeller shaft.
