Brief Description: Cowl Prep - Clearing The Openings - Part 1
Spent a brief time this evening cutting away the flat plates that block the cowl's air intake and prop hub openings on the upper cowling section. I left the folded back section around prop hub opening that formed a kind of "U-Channel". I trimmed this smooth before checking the fit of the opening around the prop hub outer circumference.
Cleaning up the edge after cutting away the blocking to the air intake openings on the top cowl piece.
