Brief Description: Installed the EGT Sensor Probes
Installed all 6 EGT sensor probes into the exhaust pipes at the pre-drilled (removed the safety rivet) locations. Inserted the probe tips, and tightened the hose clamps to snug the seal.
Right side EGT sensors installed.
Left side EGT sensors installed.
EGT sensor probe installation into each exhaust pipe. Installed in Jabiru pre-drilled location.
