Brief Description: Completed Fuel Line From Tank To Firewall
Completed the fuel line from the tank to the firewall bulkhead fitting with the 6 inch flexible cable from the shutoff valve fitting to the bulhead fitting in the firewall.
I didn't want the fuel plumbing from the tank to the firewall bulkhead fitting to be entirely rigid, as a hard landing could cause something to give and allow a fuel leak in the cockpit. A flexible hose line completing the connection from the fuel shutoff valve to the firewall bulkhead fitting provides a little ability to flex with the forces of a hard landing or the like.
Tightening the swivelling insert couplet to the hose end.
Thge finished flexible patch line.
The flexible fuel line patch hose completing the run from the fuel tank to the firewall.
