Brief Description: Pulled Intrument Panel To Make Final Trays
I removed the intrument panel again. I need to remake the final avionics trays using the 0.032" 6061 T6 sheet stock.
I also need to adjust the ACM hardware positions up by a very slight amount to provide better bottom clearance on the tray. Both trays need hardware attachment holes added to them for the various components that are installed.
Replaced USB charger with unit which has a Type-B and Type-C connector, plus a voltage display.
PFD tray with ACM mount to be slightly adjusted, plus various mounting holes added.
MFD tray needs various mounting holes added, then the 0.032" final made.
