Brief Description: Right Carbon Fiber Overlay Panel Cut
I found a cheap, thin and flat material to use for making final test cuts for fitting before cutting the final carbon fiber material. This is approximately the same thickness as the carbon fiber, and pliable enough to make a final fit check pretty reliable. I cut the right panel from this white test material. I made final cut line adjustments to the toolpaths and then cut the carbon fiber final panel.
The right carbon fiber panel fit wonderfully.
Cutting the final test fit pieces from cheap test material. Final fit was good.
Engraving labels and cutting the right overlay panel from the carbon fiber sheet stock.
