CHUCK'S WEB SITE
Sonex-B Tri-Gear
Final Mounting Of The ADAHRS Unit
Completed the final mounting of the ADAHRS unit.
Replaced all regular harware initially used with brass harware per requirements for the internal magnetometer.
Drilled and installed bolts for the two arced slots to provide the roll adjustability to the mount.
Preliminarily set a coarse adjustment of 0 degrees for the ADAHRS. More accurate adjustment will be set once the inuts are connected.
Replaced all mounting hardware with brass hardware, and added the two arced mounting bolts.
Side view of final mounting position and adjustability.
Final mounting position on second cross member support looking aft into the tailcone.
Sonex-B Tri-Gear Home
1153
142
Cowling
66
140
Documentation
69
81
Electrical System
232
Plans Review
