Brief Description: Finishing Primary Power Distribution Wiring
Built most of the remaining wires to complete the primary firewall power distribution system.
Connected wires between components, but have not connected either power or ground leads to the battery yet. I will run the pictures and primary firewall power wiring diagram past tech support at both Vertical Power (PPS) and Advanced Flight Systems (ACM) before connecting to battery power.
Firewall mounted primary power distribution system almost completed.
