I built up the fuel line segment that goes from the fuel tank outlet to the final elbow to connect to the firewall fuel line pass-thru union. This consisted of applying the teflon thread sealant to the male threaded sections to ensure the sealant is only pushed out of the thread union as the male threaded piece is inserted into the female threads, to prevent any possibility of sealant contaminating the inside of the fuel flow compartment.
I used way too much sealant, and will have to do some after-the-fact cleanup for appearance.
I also replaced the dual throttle slave cable to remove the temporary cable union I had made. Threaaded this cable through the mounted cable hanger and re-attached at the main and slave throttle controls. Re-threaded the solid cable line through the cable sheathing.
Removed the last two threaded plugs from the gascolator, applied teflon thread sealant, then re-inserted them and tightened them down for a final seal.
Built up the fuel strainer to Gold Cube sender unit, to shut-off valve to 45 deg elbow fuel line.
Replaced the cable sheath for the dual throttle slave cable.
Reinserted the last two gascolator plugs with sealant and set them.
