Brief Description: Cutting And Fitting Rectangular Panel Openings
Began cutting out the rectangular openings in the aluminum instrument panel for the larger panels.
Once all initial cutouts were completed, matching was fine-tuned with any required filing to clean up the match from the Carbon Fiber overlay to the aluminum panel.
Mounting holes for the mounting trays behind the SkyView HDX displays were countersunk in the Carbon Fiber overlay to allow the displays to mount flush against the overlay.
Cutting out the larger area rectangular panel openings.
The last of the cutouts removed to match the aluminum instrument panel with the Carbon Fiber overlay.
Countersinking the overlay holes to mount the trays behind the SkyView HDX displays.
