Building the prototype design fo rthe two mounting trays to go behind the 10" Dynon SkyView HDX displays. Custom building them to make the trays narrow enough to fit with the displays in their current position. To use the Dynon UniversalTrays as originally intended, the displays would have to be moved a little further apart, but they can't be moved any further apart on the small Sonex-B instrument panel.
Cut the pieces on the CNC. Bemt the flanges on the bending brake. Drilled for and mounted the nut plates. Riveted the bottom plates to the side panel flanges. Test mounted the trays to the masonite instrument panel mock-up.
Drilling the mounting holes for the nut plates on the side panel mounting flanges.
Riveting the bottom panel to the side panel bottom mounting flange.
Mounting tray prototype mounted to the masonite instrument panel mock-up.
