Brief Description: Re-installing The Fire Sleeved Fuel Lines
Re-installed the firewall side fuel lines after fire sleeving them.
I first sealed the gascolator's NPT fittings with teflon paste and tightened them in position.
I then in stalled the shorter newly sleeved fuel line from the firewall through fitting to the gascolator, then the second longer line from the gascolator to the AeroInjector.
Ensured fittings were tight and completed the firewall forward fuel lines.
Re-installed the NPT hose fittings on the gascolator with teflon paste.
Installed the fire sleeved fuel lines and tightened the AN fittings.
Fire sleeved fuel lines from firewall fitting, to gascolator, to AeroInjector.
