Brief Description: Finishing Regulator Mount Prototype
I finished making the voltage regulator firewall mounting platform prototype from cheap 0.020" "big-box store" aluminum sheet stock. The design layout works fine. Ready to cut from 6061-T6 0.032" aircraft aluminum stock sheet.
Wire distribution to the terminal strip studs.
Underneath side and firewall mounting tabs for the regulator mounting base.
Auxillary cooling fan support cage clecoed in place.
