Brief Description: Designing CNC Layout Of Gascolator Bracket
I made three design passes at the gascolator mounting bracket, cutting each out from cheap big-box 0.020" aluminum sheet stock material. Test piece was bent to check form, and any adjustments made for another pass if needed.
Once the design was finalized, it was saved to use for cutting the final bracket from the 6061 T6 0.032" aluminum sheet stock.
Second design pass at the gascolator mounting bracket.
Third and final design adjustment of the gascolator mounting bracket, cut from 0.020" test aluminum.
Final gascolator mounting bracket CNC CAD design with toolpaths overlayed.
