CHUCK'S WEB SITE
Sonex-B Tri-Gear
SNB-G01
Fabricating Gascolator Bracket
Cut final gascolator mounting bracket flat form from 6061 T6 0.032” sheet stock.
Bent gascolator mounting bracket flat form into final bracket, ready to position on the firewall and mount the gascolator.
The unbent flat part cutout for the gascolator mounting bracket.
Brake bending the gascolator bracket to shaped form.
The bent and completed gascolator nounting bracket with gascolator, line fittings and drain valve.
Sonex-B Tri-Gear Home
1153
142
Cowling
66
140
Documentation
69
81
Electrical System
232
Plans Review
