Brief Description: Finalizing The Oil Cooler Instalation
Dissassembled the oil cooler system to re-install permanently.
Applied teflon paste to all required joints to seal and re-installed the oil cooler system, tightening all paste sealed NPT joints, as well as all tightening all AN connections to a tight seal.
Tightened all mounting bolts to secure and finish the oil cooler system installation.
Teflon thread paste applied to both oil cooler hose fittings and installed, then hoses tightened on.
Oil cooler and baffle assembly installed under the engine.
Teflon thread sealant applied to oil cooler adapter nipples and installed. Hoses attached/tightened.
