Building hoses to plumb the oil cooler system. Built the 12" hose to go from the engine oil cooler adapter to the left side of the oil cooler.
Built the second oil cooler hose to go from the oil cooler adapter to the right side of the il cooler.
Made all connections for the oil cooler and the dry-fit looks good. Ready to dissassemble and use teflon thread sealant to make the installation permanent.
Dry-fitting first hose between oil cooler adapter and the left port of the oil cooler.
Securing the longer hose from the right side of the oil cooler with a cusioned clamp onto the intake.
Oil Cooler and baffle assembly in place with a dry plumbing fit. Ready for sealant.
