CHUCK'S WEB SITE
Sonex-B Tri-Gear
SNB-P10
Assembling Oil Cooler Components
Started on oil cooler by trimming off bottom flange on front bottom edge.
Fit oil cooler bracket to engine intake and drilled.
Deburred oil cooler baffle.
Loosely mounted the oil cooler baffle to the oil cooler. Mounted this oil cooler assembly to the bottom of the engine intake.
Trimming the lower front edge flange off the oil cooler.
Cooler and intake maounting brackets attached to the cooler.
Oil cooler and baffle assembly test fit to the engine intake.
Sonex-B Tri-Gear Home
1153
142
Cowling
66
140
Documentation
69
81
Electrical System
232
Plans Review
